How to run conex-cc driver
I have downloaded the labview drivers for conex-cc, but I cannot run it. When I run the program of absolute move or execute started move, there is no error reported but the stage doesn't rotate.
Do I need to run run several programs at the same time or do some work previously? How can I make the stage rotate by the labview driver?
Message 1 of 9
(4,543 Views)
Hi Hanxiang,
What version of LabVIEW are you using?
Since NI doesn't provide the driver, it might be best to ask Newport for information about its use.
-sarahmo
Message 2 of 9
(4,512 Views)
Can you post a screenshot of the code that doesn't produce an error but also doesn't work?  Posting the VI would be even better.  Posting both would be the best.
Message 3 of 9
(4,510 Views)
Were you able to make it work.  I have same issue, i can make motor rotate with Newport GUI but not with programming.
Message 4 of 9
(4,228 Views)
here is screenshot of code that doesn't produce error but moto does not move.  Any help with be appreciated.
Message 5 of 9
(4,223 Views)
That screenshot you posted sure doesn't look like LabVIEW.
Did you post in the correct forum?
Message 6 of 9
(4,211 Views)
It's labwindow/cvi.  it was only place i found that people had similar issue as me.  Anyway, did anybody figure out why it does not move?
Message 7 of 9
(4,206 Views)
It looks like you're trying to initialize a NSR1 according to the comments.  Is that true?
The NSR1 only comes with the option to use a CONEX-PP RS422 controller, and it's hardcoded to use 115200 baud and not to use flow control.  You're currently using 9600 and have selected RTS/CTS flow control.  So that's the most likely thing that I can see.
Message 8 of 9
(4,200 Views)
Thanks, that worked.
Message 9 of 9
(4,194 Views)
