How to run multiple arguments with systemexec and CMD
Hi all
Trying to change folder permissions through labview. The commands I am trying to run are:
[open terminal]
ssh admin@[ip address]
chown lvuser:ni /path/to/folder/i/want/to/alter
chmod 777 /path/to/folder/i/want/to/alter
So far I have tried a variety of suggestions ive found on this forum, including trying ' cmd /c ssh admin@[ip address] & chown lvuser:ni /path/to/folder/i/want/to/alter & chmod 777 /path/to/folder/i/want/to/alte ' but this doesnt seem to work either. Does anyone have suggestions on how to do this? This code is running on a windows machine, and SSH'ing into the RT to change folder permissions on it.
(2,569 Views)
First, does this command work if you actually SSH into the rt target (I suggest using Putty for that)?
Don't  you need sudo to do a chosen?
Also if you apply to the folder, I don't think it applies to the folder's content so you might want to add arguments like * (to apply to existing files) and -R (to also include sub-folders)
You canaso use WinSCP, it offers a basic UI if you're not a command line fan
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,541 Views)
I'd try to make a .bat file and run that through system exec
Qestit Systems
Certified-LabVIEW-Developer
(2,517 Views)
Does this work?
ssh admin@host "chown lvuser:ni /path/to/folder/i/want/to/alter && chmod 777 /path/to/folder/i/want/to/alter"
I cannot try with a Linux machine, but this works with a Windows client to a Windows host and LabVIEW 2020 64 bit:
ssh User@host "mkdir test && mkdir test2"
You have to use '&&' to chain commands. Adding '&' will put execution in the backgound.
(2,501 Views)
If you need to do this from a LabVIEW application running on Windows, you could use the command line version of Putty, call Plink.
Documentation:
https://the.earth.li/~sgtatham/putty/0.79/htmldoc/Chapter7.html#plink
Download page:
https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
There are 32 and 64-bit versions, use the one that matches your LabVIEW bitness.
For sending multiple commands, try separating them using a semicolon " ; ".
(2,492 Views)
Thanks for the replies all.
This needs to happen on either the RT or a computer linked to the RT.
This needs to happen programatically, so I cant have anyone access the computer since its remote, to run these commands. I wanted to do this on startup.
I posted a similar question here but didnt get far.
(2,476 Views)
