How to run my application automatically on startup of Windows 7?
Please tell me how to automatically run my application on startup of Windows 7.
(2,926 Views)
Add the program to C:\Users\<user name>\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup. replace <user name> with a real user
hope it helps
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(2,923 Views)
Thanks.
Please tell If I have to startup my application for every user. Then what to do?
(2,921 Views)
To start your application when a user logs in, put a shortcut to your application in the Startup Folder for "All Users". The actual method depends on what OS you are running.
For Windows 7:
Go to Start Menu and Right click on "All Programs" and choose "Open All Users". Then go into the Programs folder and find the Startup folder. Put the shortcut in there.
By the way, all that information is available on the web.
(2,919 Views)
Where is this startup folder located in Windows 7? Please tell me the exact location.
(2,911 Views)
what billme said, the link below gives various options on how to do it
http://www.sevenforums.com/tutorials/1401-startup-programs-change.html
(2,910 Views)
