How to run te336x arbitrary waveform example?
Hi, our lab recently purchased a te3362 (Tabor Electronics) Arbitrary Wavefore Generator.  I cannot find the documentation to create a labview program that is able communicate with the te3362.  Where can I find the documentation?  I also tried running the  te336x arbitrary waveform example downloaded from the te download page but cannot run the example becasue of an error.
Details:
te336x Initialize With Options.vi<ERR>Driver Status:  (Hex 0xBFFF0011) Insufficient location information or the requested device or resource is not present in the system.
I am using a serial port (RS 232) and a windows computer.  The resource name on the top left of the front panel says GPIB0::2::INSTR by default. What am i supposed to change this to?
Thanks in advance!
(2,663 Views)
You're supposed to change it to the actual VISA resource that the instrument is connected to. In you case, you don't have a GPIB controller but are connected to a serial port. Change it to the com port you're plugged into (i.e. Com1 or Com2). You also have to hope that the vendor has support for a serial instrument in the driver they wrote.
Any documentation is provided by the vendor. If they followed the NI Instrument Driver guidelines, there should be a top level VI called te336x Example or Getting Started that demonstrates how to use some of the lower level functions in the driver.
(2,660 Views)
