How to run vi on startup
How can I run my VI immediately on startup without any user action?
BR,
Jick
(4,268 Views)
You mean on start-up of your computer?
Then you can use a bat-file that calls LabVIEW with the vi-path as parameter. Propably you need to add an delay (ping) to wait until all services are started. Then add this bat to the autostart folder.
Felix
(4,261 Views)
Let's make it more clear. When user launches/opens the vi, it has to run immediately.
Jick
(4,258 Views)
Accepted by topic author Jick
VI properties, Run when opened.
Felix
(4,255 Views)
This seems to work when opening a file from within windows, but when I open a VI that is set to 'run VI on open' from the project explorer, it doesn't open. Is that a feature or an error?
(4,180 Views)
Feature - expected and normal behavior.
(4,161 Views)
