How to run while loops in parallel
Hai
i am using labview 7.1
I want to read the data & i should transmit through CAN
i have two options
1) Default
2) i will read data from a file
3) By clicking on the LED indicator i will generate the data & transmit
when i run the program
if i select default data & click send default data should be send to the CAN the LED indicator will be ON or OFF
if i select Read from file & click that data i select should send according to the data LED will ON or OFF
if i select the othere option by clicking on LED it will generate the data that will be send
but always the CAN read should run and display the received data
i attached my vi please give me an idea how to do it
thanks
(2,723 Views)
(2,719 Views)
