How to run while loops parallel
Hai
i am using labview 7.1
I want to read the data & i should transmit through CAN
i have two options
1) Default
2) i will read data from a file
3) By clicking on the LED indicator i will generate the data & transmit
when i run the program
if i select default data & click send default data should be send to the CAN the LED indicator will be ON or OFF
if i select Read from file & click that data i select should send according to the data LED will ON or OFF
if i select the othere option by clicking on LED it will generate the data that will be send
but always the CAN read should run and display the received data
i attached my vi please give me an idea how to do it
thanks
(3,372 Views)
I tried to open your vi, but it requires a password... Could you give it Smiley Surprised ?
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,367 Views)
Sorry
now I removed the password
thanks
(3,357 Views)
Hi LV Beginner,
I'm not sure if your question is how to use the CAN driver, or how to organize your LabVIEW code.  If you're still learning LabVIEW, you may want to check out these Introductions to LabVIEW:
You might also find it useful to use the shipping examples that come with LabVIEW (Help>>Find Examples) or to use some of the VI templates for common VI architectures.  If you had a more specific question, it would be easier for us to help!
Happy coding,
Megan B.
(3,316 Views)
(3,306 Views)
