How to save 7.0 VI's flat sequences properly as Labview version 6.1
Labview 7.0 has a Save for previous option that allows the vi to be saved as 6.1 vi. In attempt to
do that with a VI that has flat sequence, a stacked sequence got added in the VI and a lot of things
got screwed up. Is there anything out that that will allow me not to happen, rather than manually change
the whole VI, which is going to be very time consuming?
Any help will be greatly appreciated.
Ratin
(2,843 Views)
Since LV 6 does not support a flat sequence, I'm afraid you are stuck with making the modifications yourself.  Have you tried going to the 7.0 block diagram, right clicking on the flat sequence, and selecting Replace with Stacked Sequence?  If this is successful, then you could save to previous version.
- tbob
Inventor of the WORM Global
(2,841 Views)
good idea, I will try that. Thanks a lot.
(2,837 Views)
Actually changing it to a stacked sequence messes it up as well. So I guess I am sort of stuck and have to do it manually.
(2,835 Views)
