How to save 8 bit PNG?
I found this helpful bit of code that uses .NET for capturing a screenshot using coordinates from a mouse click. However, I need it to save 8 bit PNG files instead of the 32 bit PNG it currently saves. Does anyone know how to do that?
Thanks!
(3,433 Views)
Accepted by topic author Testr00
First thought is you could use the Draw Flattened Pixmap, then the Picture to Pixmap which has an input for the depth which could be set to 8, then do the PNG save.  Nic eVI by the way.
(3,415 Views)
That worked nicely. Thank you for your assistance.
(3,402 Views)
