How to save .LVUTF File of Unit Test result in LV Unit Test Framework, Programmatically.
I'm trying to save .lvutf file of Unit Test result, programmatically. I'm able to save .html file but didn't get any way to save .lvutf file by code.
I can save .lvutf file using SAVE option and able to load it using LOAD option MANUALLY in LV Unit Test FW
Note: .lvutf file is very important file which is created after completion of any Unit Test using LabVIEW Unit Test framework. We can use the result (.lvutf File) to see the statistics whenever you will load in UTF Tool provided by LabVIEW.
Message 1 of 1
(2,577 Views)
