How to save a 3D array? Or how to save a spreadsheet string for future retrieve?
When writing a 3D array, you can split the array to some sub-arrays(3D) using shift register, write them through a loop. In the loop, a time-delay vi(for example, Wait Until Next ms Multiple vi) should be placed to prevent from exhaust the resouce of the computer.
Reading 3D array can be realized through a read vi in a loop.
There is an example.(The data type of it is U8).
Through select the proper number of the sub-arrays, the better calculating speed could be gotten.
Thank you.
Message 11 of 12
(1,108 Views)
There's an error in my program :)It's the right program.
And initializing a large array would use a long time.
If reading the data from a large file getting from others, it's not good to read all data in one reading operation. I think it's better that combining "Seek", "Eof", and "Read" vi in loop.
Thank u.
Message 12 of 12
(1,104 Views)
