How to save a TDMS file on Real-Time Target (PXIe)?
how can a file (Like TDMS) from measurement data be saved on the RT System (And later copied manually to the Computer?). As shown in the picture, of course I cannot write to the file path "C:\filename.txt" because there is not "Computer harddisk". So how to set the right filepath and where can the file be found afterwards?
Thanks very much!
(3,799 Views)
Accepted by topic author Tooly
1. Go read this: Working with File Paths on Real-Time Targets
2. You can use FTP or WebDAV to get the file that is saved on the RT.
GCentral
(3,781 Views)
Thanks!
Ok that seems to work, also I found a solution to get acess via Webbrowser:
Type: http://ipadress/files/ where you can download the files...
(3,755 Views)
