How to save a "write to spreadsheet file" as read only
I'm writting data in a loop into a write to spreadsheet vi. when it's complete I want the file to be read only when it is opened in excel.
(3,357 Views)
After you finish writing to file, use some Advance File VIs & Functions to change the attribute of the file.
Specifically you might need to use 'Set Permissions' funciton.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,352 Views)
Accepted by topic author Zyshan
In the File I/O->Advanced pallete there is a function called Set Permissions.  Please read the help file on this function and follow the link to how to set the permissions.
(3,349 Views)
Problem solved. Thank you very much for your speedy replies.
(3,338 Views)
