How to save a series of images as sequentially numbered files
I have written a program to send a scan pattern to a moving mirror, loop the scan process for a defined number of itterations, and save an image of the scan recorded by a simple detector. I am trying to save the image geneated by each scan as sequentially numbered files, so if I do 20 scans I have 20 files called image 1, image 2 etc. I've looked at the examples bundled with LabVIEW and haven't found anything useful, and have attached the program I'm working with.
I'm not really much of a programmer or LabVIEW user, so if the solution is obvious I apologise.
Thanks in advance,
Ben
(2,465 Views)
Hi Ben,
a quick starter:
(2,462 Views)
