How to save an image from an ROI and then convert to an array of pixels?
I am working with a USB CCD camera and LabView 2012 on a project. Using some drivers that came with the instrument (imaging source USB CCD drivers) I created a program to display a live feed image and then grab an image and select a ROI. I need to convert this ROI to a new image and then save it, but I am having trouble doing so. I also will need to convert the ROI image to an array of pixels, and I don't know how to go about doing that either. Any help is appreciated! I attached my attempt at the program so far.
(2,915 Views)
Accepted by topic author kloram333
Hello Kloram,
Here are some examples that I have found from our NI Community pages that perform your desired actions.
[1] Create an Image from ROI
[2] Create New Image from User Selected ROI
Then simply use the following functions from the Vision Development Module in conjunction with the previous examples to achieve your application:
- IMAQ ColorImageToArray
- IMAQ ImageToArray
Huntington W
***Don't forget to give Kudos and Accepted as Solution where it is deserved***
(2,893 Views)
