Thank you john and evan,
I use, as you've understand, the invoke node "get all control value variant", and i want to change the format of the output array in order to save it an load it later to get back the configuration of my VI. For the moment i've try as john tell me with the data manipulation's functions and it's not runing. I send you an example of the code that i read in the array it's a string for controls name and a variant for the values.
I don't really now in what format i must change them to load it later with the invoke node "set control value".
Regards
alexis (sorry for my awfull english)
