How to save and load positions and layer orders of front panel controls?
Hi, demo.vi can move controls using mouse click event and changing layer order of front panel controls using shortcut menu. I want to save and load controls positions and layer orders programmatically, how to save and load positions and orders?
I have attached my vi,
Can anyone help?
Himmet GENCER
Software Development Coordinator at TDG
himmetgencer@gmail.com
View Himmet Gencer's profile on LinkedIn
View on Instagram
(5,134 Views)
Use property nodes to get the values of these properties (e.g. position, z-index) and write them to a configuration file on exit. When your VI starts, load them back from the configuration file. You can use the Ctrls[] property of a VI Pane to get an array of all controls/indicators.
(blog)
(5,121 Views)
Thanks Sam,
But I can't find z-index of controls. How can ı find this property?
Himmet GENCER
View on Instagram
(5,117 Views)
Ah, you said that the VI you had was able to change the ordering - so I assumed you could use the same method to get/set the order.
It doesn't look like it's a property for that - but I did find this idea: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Programmatic-Manipulation-of-Object-Layer-z-order/idi-...
(blog)
(5,109 Views)
