How to save as an executable?
Hello everyone!
I am trying to see if I can save a LabView program as just an "executable" where I can give to someone and they can only 1) run it and 2) enter inputs in front panel where required by users.  Sorry if simple ... even sorrier if it's not do-able 🙂
(4,145 Views)
You need the application builder... but I do think there is a LabVIEW player out there somewhere, but not sure if that is an add on or something that you can use independantly.  But something you can search the NI website for.
Paul
(4,138 Views)
The LabVIEW player has not been available for several years.
The app builder is included with the pro version of LabVIEW. Otherwise, it is an extra cost add-on.
(4,122 Views)
And after you get the application builder you need to right click build specifications goto new->application(exe) and than enter in the properties your want
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(4,113 Views)
Not to mention that your code needs to be part of a project to build an application now. (Not that I see this as a bad thing)
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(4,107 Views)
Accepted by topic author seeminus
And here , a step by step description is giving how to build an exe.
Somil Gautam
Think Weird
(4,097 Views)
