How to save measurement file from a web published VI
So I created the following HTML:
http://julian-pc.cecs.ucf.edu:8000/thermocouple%202.html
I need to enable the clients to receive the file with the data. Right now the client can run it perfectly but the data file is being saved on my pc.
Thank you for your help.
Julian Sanchez
Mechanical Engineering Student - University of Central Florida
Research Intern | CASER
C. 407.744.4174 | E. julians2009@knights.ucf.edu
(2,510 Views)
Hi Julian,
There's a couple different ways you can look to go about doing this, both of which have detailed kb's that you can follow.  The first is for if you're sharing the same network as the client, and the second is if you don't share the same network.  While the title of the second link mentions .htm report, the solution part of the kb actually describes how to do it for files in general.
Can I Save Data from a Remote Front Panel to the Client Computer
How Do I Display a Server Based .htm Report on a Client Machine
Hope that helps you out.
(2,487 Views)
Good morning,
Thank you for the reply however I am not able to open the link on any internet browser. Is there possibly a way that you can send me the document in a file format?? Also to add to the question, how can I get the published VI to be viewed from a client connected to a different network??
Julian Sanchez
(2,470 Views)
Hey Julian,
Here are the links in a format you should be able to open:
Can I Save Data from a Remote Front Panel to the Client Computer?
How Do I Display a Server Based .htm Report on a Client Machine?
Trey C.
(2,455 Views)
