How to save numbers and words in the same file
Hello:
I've done a vi where I record the spectrum and it's integration in diferent positions of a bidimensional net. I save the information in two spreadsheet with the comand "write to measurement file".
Now I'm trying to save the parameters Initial X position, end X position and space between measurement points. I want a file with two columns wich looks like:
Initial X position   1000
end X position      2000
space                 100
But Idon't know how to save words and numbers in the same file.
As I have to do several measurements I want to choose the name of the file automatically (something like parameters_1, parameters_2...)
Thank you for your atention
(2,564 Views)
Accepted by topic author bitxor
Hi bitxor,
you could use any of the WriteTotext file functions to write strings to a file.
Then you could configure WriteToMeasurementFile" to append new data to existing files (instead of overwriting or renaming them)...
Btw. it's not a good idea to mix up lvm files with arbitrary spreadsheet data!
(2,562 Views)
Thank you for answering so fast.
I think I'll use a write to measurement file and commen in the header what parameters are saved
(2,551 Views)
