How to save numerical values ​​in one VI and open those same in another VI
i have this interrogant, i dont have solution, please i need help.
(2,991 Views)
Normally you send data through the wires, and send it to and from VIs through the Connector pane. So send data out from the first VI and in the other.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,989 Views)
What really are you trying to do?
You can use:
1. Make values default, make that VI into a subVI and using it in the other VI you want to use the values.
2. Use a global variable
-Andrea Gamboa
(2,909 Views)
