How to save several 1D arrays to an array in FPGA
Hi!
Any advices are welcome!
I'd like to know
1.  how to save several 1D arrays to x-D array on each dimension.
Data type is Fixed point.
1st 1D array to 1st column in the array.
2nd 1D array to 2nd column in the array.
3rd 1D array to 3rd column in the array.
4th 1D array to 4th column in the array.    .....                   in FPGA VI.
After creating the array in FPGA,
2. How to save the array as an excel format in RT VI?
Thank you so much.
(5,292 Views)
Build Array should do it for you.  Just all of the 1D arrays have to be fixed size and the same size.
Now for passing them up the the RT, I recommend using a DMA FIFO.  Then it should be simple to use the Write To Spreadsheet File to write a tab delimited file that Excel can read.
(5,272 Views)
Thank you!!
Can your suggested way, Build array, arrange the my data in each different column?
I used the  'Insert Into Array' function and it is good to arrange the data in a VI. (Not FPGA VI)
However, in case of FPGA VI, I got some Errors " Maximum number of array dimensions exceeded."
Each 1-D array has 97 data points in a column.
Is that a limitation of FPGA compliation?
(5,243 Views)
Accepted by topic author catalysthw
Hi catalyst,
it seems the FPGA does NOT like your 2D arrays…
The FPGA is very limited when it comes to array handling. One limitation is: you can only use 1D-arrays, the other is the fixed array length.
This is very basic LV+FPGA stuff: did you read the LabVIEW help? Did you read the LVFPGA beginner tutorials on NIs website?
Initialize an 1D output array with 5×97= 485 elements. Use ReplaceArraySubset to replace parts of your output array…
(5,215 Views)
There are two ways of combining several 1D arrays into bigger one:
1. build array, but with concatenate option enabled (just right clik on build array and check "Concatenate Inputs"). This will give you 1D array on the output with sequentially placed input arrays.
2. Use "Interleave 1D Arrays" VI. Again you will have all input arrays combined into 1D array, but in this case the samples will be interleaved
Making LabVIEW Smrter and Faaster
(5,178 Views)
