How to scale current output?
Hello everyone!
I have a pressure transducer that has 4-20mA output, I'm wondering if someone could tell me how to scale current. I know I can put resistor accross the output to produce voltage but I want to do it in current.
Here's my hardwares:
Cole Parmer - Pressure Transducer
Power Input: 24vdc
Output: 4-20mA
Range: 0-100 Psi
PCI-6024E (I also have PCI-6259)
SCB-68
Thanks!
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
Message 1 of 13
(6,198 Views)
if 4 mA corresponds to 0 psi, and 20 mA corresponds to 100 psi, then the 16 mA range covers 100 psi.  so 100psi/16mA = 6.25 psi/mA.
Given 6.25 psi/mA, and 4 mA = 0 psi, it's a y=mx + b kind of thing to find the offset.  0 = 6.25*4 + b, so b= -25.
so your scaling factor will be PSI output = 6.25 (mA output) - 25
edit - a sanity check shows that (6.25*20) - 25 = 100, so you know you're on the right track
Message Edited by JeffOverton on 04-24-2008 01:41 PM
Message 2 of 13
(6,194 Views)
Thanks for a quick reply!!!
______________
KowdTek
LabVIEW 2009
Message 3 of 13
(6,188 Views)
Unfortunately, my card (6259) cannot read current so I end up putting 249 ohms resistor across the output to produce 1-5vdc then set the daq assistant to read voltage. The transduders range is 0-100psi (@1-5vdc) and I set the scaling parameters to 25 for slope and -26 for y-int. My question is why the reading stops at 29psi? Note that I had it hooked up to a pressure regulator with digital meter for comparison, also the output is 5vdc which supposed to read 100psi.
Thanks!
Message Edited by FlipTek on 04-29-2008 06:24 PM
______________
KowdTek
LabVIEW 2009
Message 4 of 13
(6,149 Views)
Well, your offset should be 25, not 26, but the rest of it is a lot more of a gray area.  It could be hardware, you could have scaling enabled somewhere in the daq software, your measurements might be affecting the readings, etc.  Sorry I can't help you more, but I'm not that familiar with NIDaq or the daq hardware.
Message 5 of 13
(6,126 Views)
In addition, I've observed that the same application works when I used PCI-6024. Why it doesn't read the full scale when I'm using
PCI-6259. I checked the test panel and it reads 0-5V but somehow stops at some points (29psi) when I run the vi.
Please let me know if there's anything I should do to resolve this issue.
Thanks!
______________
KowdTek
LabVIEW 2009
Message 6 of 13
(6,080 Views)
When using the PCI-6024E and the PCI-6259, are you using the same code and task configurations.  I am specifically interested to clarify that both are using the same scale and mode (single ended or differential).  I am unsure why you are limited to 29 psi on the 6259, which is related to 2.16 V as an analog input and 8.7 mA for the sensor output.  Can you verify that the signal is in fact higher than this at the time you are measuring 29 psi?
Samantha
Message 7 of 13
(6,068 Views)
Hello Samantha!
I am using the same code and task config so as the scale and mode. As I apply more pressure  the signal goes up but the actual reading stays at 29psi.
Hoping that you could help me figure this out.
Thanks!
______________
KowdTek
LabVIEW 2009
Message 8 of 13
(6,058 Views)
Lets try testing the 6259 by creating an analog output 5 V and wiring it into an analog input channel.  Another good test will be to send a 0-5 V sine wave into an analog input to check its response.  All this testing in independent of the code and configurations you are already using.
Then, I would suggest testing an analog input with your code but where the signal is coming from an analog output from the 6259 rather than the sensor.  I understand your code is intended to test current. So this last test would be without the 249 ohm resistor.
Let me know if the 6259 is working with these tests.
Samantha
Message 9 of 13
(6,000 Views)
Both test works just fine. I also test the input receiving a signal out of regular power supply.
This 6259 is realy flakey to me because we have another PC that has the same daq card and when I tried the code it works.
It's just too expensive to act up like this.
Thanks for your time Sam!
______________
KowdTek
LabVIEW 2009
Message 10 of 13
(5,987 Views)
