How to scale the value displayed in DSC Alarm
     I can able to see the alarms generated, using alarm event display. But  i like to scale the value shown in the alarm event display table. Whether its possible to scale the value in that table itself. I had attached my image file of this. I am looking forward for your valuable replys.
with regards
vijay
(10,643 Views)
Ur attachment is missing... Smiley Surprised
- Partha ( CLD until Oct 2027 🙂 )
(10,619 Views)
Hi Vijay,
There is a great KnowledgeBase article that I found about the considerations needed to take when scaling with memory tags in LabVIEW DSC. Also, are you trying to scale the values before they get to be displayed in the table? I think that the attachment to your post is missing. Could you attach it so we can take a look at it? Also, there is a lot of great information in the DSC Module How To help. You should take a look at the information provided for alarming.
Carla
(10,584 Views)
(10,068 Views)
  Here i had attached the image file,  In this I like to scale the value only when its displayed in the Alarm&Event Table.Can you give some suggestion on this.
Regards
Vijay_Conz
(10,066 Views)
Hi Vijay_conz,
Unfortunately, you cannot scale the values displayed in the Alarm and Event table. Since you are inputting the values into the table, you can scale them before they are recorded into the table but you cannot alter them once they are in the table. You can either scale the values before the are recorded in the table or you can try to create your own customized alarm and events table using Xcontrols. There is a good example of what this entails in the NI Example Finder. It is called Custom Alarms Display.lvproj and can be found by searching alarms. I hope this helps!
Carla
(9,729 Views)
