How to scan quoted string
I hate asking stupid questions, but I am stuck ...
Given a string with a quoted substring - how do I extract the quoted substring?
For ex: balh blah blah blah "quoted text" blah blah blah ...
I want to pull everything out between the quotes and I know the index of the fist Quote (or possibly the space before it).
I thought I could simply use Scan String For Tokens with a Double Quote as a delimeter, but that doesn't seem to work.
Is there a special way to enter the " as a character/delimeter?
Any ideas?
- Rick
(3,973 Views)
Is this supposed to happen more than once? If not, it would be easier to just use the Match Pattern function:
Otherwise you can use the Scan String From Tokens function this way:
Message Edited by smercurio_fc on 06-23-2008 01:35 PM
(3,966 Views)
Thanks!
I thought that is what I did, I'll have to compare ...
- Rick
(3,954 Views)
Ok, I entered your example and am still getting the same issue.
I get a "-1" for the token index after the first pass through the Scan For Tokens VI.
Can you take a look at the attached and tell me what I am doing wrong?
I'm missing something simple ..
- Rick
(3,937 Views)
Never Mind - I see the error ...
(3,934 Views)
