How to select DAQ card
Hi All
I want to know that what are the parameters we should keep in mind while selecting a DAQ card. ? Please reply as soon as possible.
J
(3,325 Views)
Also tell me...how to decide ...when to use Single ended Analog Input or Differential Analog Input
Regards
J
(3,314 Views)
In this Page, go to section 'Find the Right Data Acquisition Device'
It will help you in choosing a suitable DAQ card based on number of parmameters like:
Bus type, OS support, Analog/Digital Input/output, counter/timers channel count, Measurement/generation range, sampling/update rate etc
(3,315 Views)
Hi J,
Hope you follow devchander's advice, it is a great tool.
Here is a document to help you out with the difference between differential and single ended.
Good luck,
Gerardo O.
RF SW Engineering R&D
(3,297 Views)
