How to select Module for NI-9262 Reset I/O Method Block using Input Argument instead of Parameter
Hello Support,
In the following URL Links:
1>
https://www.ni.com/docs/en-US/bundle/ni-compactrio/page/ni-9262-fpga-interface.html?srsltid=AfmBOoo6...
2>
https://www.ni.com/docs/en-US/bundle/lvfpga-api-ref/page/vi-lib/eio/eiogrowablemethodnode/fixedmetho...
You will see Reset I/O method has "FPGA I/O In" input argument.
How to use that input to select a FPGA Module.
I can select Module for the Reset I/O in the Pop-Up of menu of the Block, which is essentially Hard-Coded in the LabView Model now.
Instead if I want to use the Reset I/O Block inside Sub-VI, then I need to provide that "FPGA I/O In" input to select the respective Module I suppose.
Question is how?
I can select Module Pin as Input in the LabView Model for that Reset I/O Block but not the Module.
So, please help by providing a VI if possible or some detailed hints.
Best regards
Message 1 of 1
(307 Views)
