How to select a column to display it information??
Hello,I am new to labview. What should I do so that when I type the student admission number( in "student Admission" text) then it will display only the student name or grade(in the table). I make a simple database using Microsoft access.
The database file need to be in .mdb format.
Thanks 😄
Message 1 of 11
(3,825 Views)
Thanks 😄
Since you are new to LabVIEW start with the tutorials. http://www.ni.com/academic/students/learnlabview/
Message 2 of 11
(3,806 Views)
Is this an actual application you are working on, or are you just messing around?
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 3 of 11
(3,800 Views)
Sounds more like a homework assignment to me.
Message 4 of 11
(3,796 Views)
And the example does not make any sense. There is Access ActiveX properties and methods as well as a function from the database toolkit. If you have the database toolkit, it's silly to use ActiveX. Even if you don't have the toolkit, it's silly to use ActiveX when there are other free database toolkits available (i.e. LabSQL). It's a simple SQL query so I would recomend you start with tutorials of that.
Message 5 of 11
(3,790 Views)
Yes, but it's also Summer and I gave him the benefit of the doubt.
Message 6 of 11
(3,783 Views)
I already started on the tutorial. But still dont understand how it works with database.
Message 7 of 11
(3,766 Views)
Ya.Is an actual application I am working on. I found this one the other webs, and my teacher in charge asked me to modify it.
Message 8 of 11
(3,764 Views)
Yes is a assignment.
Message 9 of 11
(3,763 Views)
I search on google about simple way to do database with labview..and i found this.
Message 10 of 11
(3,762 Views)
