How to select a frame from a sequence of images
Hi there,
i made a simple VI which takes a 3 dimensional array as input "which is 100 images". The first dimension shows the number of the image "page", the second dimension shows the pixels in Y-achse and the third one shows the pixels in X-achse. how can i select one image of this sequence individually and show it indivdually from the other images?
thanks..
(2,389 Views)
You would use the Index Array function.
When posting images, please post them to the message as .png attachments.  Posting them as part of a .pdf file takes up more space and just doesn't look as clear.
It seems you are new to LabVIEW.  I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(2,386 Views)
