How to select the last elements in a string
@RuiZanzibar wrote:
Hello
I forgot to tell that i have a start (7B7B) and end (7D7D) frame in the broadcast, thats why the index must be (n-1).
Hugs
That still makes no sense.  If you must end wit ha 7D7D, then you should be using n-3 to eliminate that footer.
Message 21 of 23
(865 Views)
Here, this will explain what I'm trying to say.  Notice that the element I got removed from the Delete From Array is the same as the indexed element at index n-1.  I'm trying to make your code simpler here.
Message 22 of 23
(855 Views)
And here is your code simplified to just a few nodes.
Message 23 of 23
(846 Views)
