How to send I16 bits to Analog Out instead of using FXP data type with 9637?
Hello, I have some older code examples for an sbRIO where the wire data type into the FPGA IO node for Analog Out is I16.  I would like drive my 9637 outputs the same way, but they appear as FXP terminals with a +/- 10 range.  I did not find properties settings that allow me to change to using raw bits, can someone point me to that option?  I understand there are some nice calibration aspects of the FXP data type but in this case I would like to try using I16 to drive the 16 bit analog outs.
JEB
(3,354 Views)
Hello JesseBuck,
Thank you for the question. I wanted to link you to another thread which shows how to do this with our sbRIOs using C series modules. Like you noticed however, this option does not exist for the Connector0 analog inputs or outputs and may not be supported.
Did your previous sbRIO use any C series modules with a RIO Mezzanine Card? Which model sbRIO was this?
The discussion mentioned above for reference:
Real-Time Measurement and Control Forums - Change Data Type for FPGA I/O Node
Alex C.
ni.com/support
(3,290 Views)
OK, thanks.  I had looked at the AOn properties but the outputs are not offering me any choices, so I guess that settles it!
JEB
(3,278 Views)
