How to send only 1 byte hexa code using VISA send for every 500 ms?
I would like to send only 1 byte of hexa code from LabVIEW to a external device using RS-232 (300bits/s, 8-bit data, no parity bit, no flow control) every 500 ms.
The TX pin on the computer should stay at logic 1 level once it finished transmitting the 1 byte of data and wait for 500 ms before transmitting again.
I build a test code below:
The "String 1" output will be connected to the write buffer of the VISA Send. (Please note that the code above doesn't include the delay of 500 ms that I mentioned. Just ignore that for a moment.)
Will this code work as what I described above? I tried it on my project, but I was receiving weird things on the device.
Do I convert the hexa code correctly?
And how the VISA Send transmits the string? Does it include other "unneccessary" strings with the hexa code that I want to send?
Any help will be appreciated.
Thanks.
(2,927 Views)
U converted to hexadecimal correctly but check the bytes.To which instrument u sending this data.Dont forget to put the delay inside the while loop otherwise its heats up ur processor.
http://forums.ni.com/ni/board/message?message.uid=921526#U921526
Message Edited by Baji on 06-09-2009 04:33 PM
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(2,923 Views)
Accepted by topic author eddiechai2003
Hi eddiechai...,
you'll get a string of length 2 so you have 2 byte. You should use the to U8 and the type cast function. (see the attached picture). You have to disable the termination character to get what you want.
Mike
(2,917 Views)
Thanks MikeS81,
That is exactly what I want.
(2,888 Views)
