How to sense the edge in digital pulse ?
Hai All,
Iam new to labview. Iam using labview8.6. In that i am having two digital pulses. Both digital pulses are not in same phase. So i need to find which digital pulse is leading other and same time i need to calculate no of pulses also. whether edge sensing is possible in labview? If it is possible then where i get edge detection in labview ?. Help me....
Thanks in advance
Sourav
(2,411 Views)
Sourav,
i assume that you are talking about external digital signals, so e.g. TTL pulses on a hardware.
If so, you will need a measurement hardware capable to do this. LV can be used to program such an application but without hardware, it is impossible. Contrarywise, the way how to implement this depends on the hardware, so we cannot give you valuable hints right now.
Norbert
Norbert
Expert: Geometry
(2,405 Views)
