12-01-2010 02:39 AM - edited 12-01-2010 02:46 AM
Before I start. I've been reading om the internet (USB tutorials, nuggets, etc.) for the last 2 days to get this,
but it is really confusing and I still have no idea how to do this. So I'm asking for your help.
I setup a custom USB device in MAX.
I need to sent this command: 0x2 M 1 0x3
Were 0x2 defines the start and 0x3 defines the end of the command.
I think I have to use a control transfer, but I do not understand what to use at the Index, Value, Request Value,
Request and Length inputs. I also do not understand how to sent Hex, Dec and ASCII at the same time.
Do I need to convert these values?
I would really appreciate some example code. Can I use the VISA commands?
Kudos will be given, thank you in advance ![]()
Solved! Go to Solution.
12-01-2010 05:08 AM
Hi!
Maybe this can be useful:
(it's about VISA communication with USB devices)
http://zone.ni.com/devzone/cda/tut/p/id/4478
Marco
12-01-2010 09:41 AM
I am not sure about the Index, Value, Request Value,
But about sending your comand....
I assume the space before the "M" and the space after the "1" is not needed,
but the space between the "M" and the "1" is needed
