How to separate signal from waveform chart
Hi everyone,
I'm using Arduino interface with Labview for acquiring signal. I use Analog Read N chan function. When I run the Labview. All signal display on a chart. I'd like to separate them to process later. How can I do that?
Message 1 of 10
(6,679 Views)
Accepted by topic author lucbk
Hi holucbme,
You already "separate" those signals by using the ArrayToCluster function…
General hints:
- Use shift registers to keep your own history of the measurement data.
- Use IndexArray function to get "signals" from your array - converting arrays to clusters is quite Rube-Goldberg!
Message 2 of 10
(6,659 Views)
Index the element you want from your output array.
Message 3 of 10
(6,657 Views)
Thank 2 bro 🙂 I did it.
I also want to ask a small question. Before, I used the LIFA (not LINX like now) to acquire the signal. In LIFA, It had a continuous acquisition sample function which I can set the number of samples and sampling rate. My question is: where I can set the number of samples and sampling rate with LINX.
Message 4 of 10
(6,635 Views)
Hi holucbme,
I think this is explained in the LINX community
Message 5 of 10
(6,623 Views)
Many thanks!
Message 6 of 10
(6,618 Views)
Sorry for my silly ask again.
After I read out signal from Index Array VI, I want to see the its spectrum. When I wire it to Build Waveform VI, the signal in time domain looks fine but I didn't see its spectrum. Can you please help me to find out where is my problem?
Message 7 of 10
(6,564 Views)
Hi holucbme,
so you create a waveform with exactly one sample in it.
From this single sample you try to calculate a spectrum - you know this is plain silly?
For a FFT calculation you need to collect some samples: the more samples the better the frequency resolution…
Message 8 of 10
(6,559 Views)
Thank for your quick answer.
I use Initialize Array VI to collect 100 samples but the spectrum isn't right. (I generate sin wave Vpp=3V and frequency = 10Hz from function generator.1.PNG2.PNG
Message 9 of 10
(6,554 Views)
Hi holucbme,
Wrong!
You don't "collect" samples by creating an array of 100 identical elements!
Btw. the spectrum is completely correct for that type of array: just a DC components and some noise due to computational residues…
Solution:
Collect those samples!
To collect data in an array you need a shift register and a BuildArray function!
(This is basic LabVIEW stuff so I recommend to take the FREE beginner tutorials offered by NI.)
Message 10 of 10
(6,542 Views)
