How to separate the X array and the Y array in a cluster with just 1 X array and 1 Y array.
Good day all,
I am working with labview Sound and Vibration Toolkit. I have been able to  get my FFT. The Labview help suggest that this was done using svc_Convert Array of Peaks to XY format VI. The peaks returns a cluster of an X array and a Y array. Please is there anyway I can separate this into the two; I mean X array separately and Y array separately.
Note: It is just the Graph with X and Y axis, but I want to separate them and use the values of X separately and values of Y separately.
Thanks all.
(2,304 Views)
Unbundle or Unbundle by Name on the cluster palette.
(2,299 Views)
