How to set Cluster size programatically
Is there a way to set the size of a cluster programatically?
Marce
(3,794 Views)
I came up with an alternative for the fact that the cluster bounds property is not writeable. It came out quite elegant. Hope it's what you are looking for.
aartjan
(3,791 Views)
Aartjan :
Nice trick, I love it !
CC
Chilly Charly    (aka CC)
(3,779 Views)
I am adding this to my user library as a merge vi, so the refnum, subvi and cluster with two string controls are always together. Very useful. If you make sure that the string controls are in position 1 and 2, you can omit the piece of code that searches the correct refnums (the while loopin the subvi). You can also replace the invisible controls with controls you are actually using in your cluster.
aartjan
(3,776 Views)
Hi Aartjan !
Here is another version of your idea. No string ! And another trick...
CC
(3,768 Views)
As a matter of fact much more elagant then mine. Stars for you, CC.
aartjan
(3,766 Views)
