How to set X axis scale as seconds on graph
I am using LabVIEW 2012 version. I want the user to select different sampling rates like 4000 Samples per second or 5000 S/sec or 10000 samples per second.
When user chooses different sampling rate, accordingly the X axis has to set to display seconds. How to do this let me know.
I have tried X axis offset and multiplier but this takes the previous setting and multiplies. I want multiplier to change according to sampling rate.
(2,979 Views)
Hi hemagopal,
you used the correct properties, but apparently in a wrong way!
Your "previous settings" sound like a race condition due to overuse of local variables (or like)…
(2,962 Views)
