I am using a VI front panel to display an image. The VI loads an image dynamically and shows it in a picture control. The width of the panel and the picture control are set identically to match the image width, and a vertical scroll bar takes care of the difference in height.
My question is, how can I make the user unable to scroll beyond the image area? For example, I place the picture control at the top-left of the panel, then when I run the VI it shows the image correctly so that you can see the upper part of the image in the window, but you can also scroll up or down all the way to see a gray area that is not occupied by any controls. Is there any way to show just the area I want, even if the user scrolls all the way? Thank you.
Message Edited by ondal on
08-12-2008 11:02 AM
