How to set front panel size to adapt to any screen size/resolution
I designed an HMI with LabVIEW using my Laptop which is roughly 12". The front panel size was referenced to my laptop screen. The ultimate destination where this HMI will reside is on a computer with larger screen size.
Please is there a way in LabVIEW to adjust the front panel size so that irrespective of the screen size, the front panel size will adjust according without distorting the design?
Thank you.
(977 Views)
Hi aig7,
you can use splitters to define panes within your front panel. You can define scaling options for each pane...
Btw. It's easier to design the front panel for the target instead of your development computer and rely on scaling...
(947 Views)
Thanks @Carya
(872 Views)
