How to set ini-File modifications permanently
Dear All LabView Pros
It became necessary to change my LabView program to Unicode. Therefore, I had to add "UniCode=true" to the ini-File of my exe.
Unfortunately everytime I rebuild my exe the ini-File gets re-written but without my modifications.
How can I set my modification permanently?
Cheers
Ben
Stay Hungry, Stay Foolish
(4,156 Views)
Hi Benjamin,
include the edited INI file in your project.
After having done so you can include that INI file in your Build specifications…
(4,152 Views)
ha!
If everything would be that easy!
Thank you for your quick reply
(4,143 Views)
Just as a wrapup of this topic here is a screenshot of the corresponding setting in the Build-Specification.
Peter
(4,098 Views)
Including your own custom INI is probably the easiest solution.  But another solution I've seen done which has its benefits, is to use the Post Build feature of the application builder.  Here you can specify a VI to run after a build is done.  This VI that runs can then edit the INI file for the application that was just built to always have the INI settings you want.
In my mind this is a more modular solution, because it can work on any project, where including your INI file only works if you have an INI file, and in that file you know the name of the application being built.  Renameing the application, or taking the INI to another project means you need to remember to edit that INI.  But running a Post Build VI can get that information and set the file for you regardless of the application name.
(4,085 Views)
