How to set input range on my NI 6221 in LabVIEW?
Hallo Alles! Robot surprised
I've been trying to do some analog voltage measurments with an NI 6221-card in LabVIEW, but I was thinking that since the specification for this card lists four different input ranges available (+/- 10, 5, 1, and 0,2 V) this input range could be set to the smallest range required for a specific measurment to acquire higher accuracy, am I right or what?
How is this accompolished on the block diagram? I've managed to generate the following via the DAQ Assistant:
Could the minimum/maximum input values be changed to achieve this? Maybe this code within a while loop + a case structure could redo the measurment until the smallest possible range was used?
And another thing, I've never done any of this "ni-daq programming" before, and I'm still pretty unexperienced with LabVIEW Robot Very Happy, but what other ni-daq actions should be included before and after a measurment like this takes place in an application? Should there any "init/clear"-commands or something? What else must one think of when acquiring data like this?
Thanks alot in advance Robot wink
(2,562 Views)
Hi OscarJ
There are some fantastic examples of DAQmx code to be found within the LabVIEW Example Finder, these are a great place to start.
They can be found within LabVIEW by going to Help>>Find Examples... and then navigating into the appropriate folder as shown in the jpeg I have attached.
Regards
Steve
(2,542 Views)
