How to set name and Range of X-axis in waveform-display
I totally forgot about that...which is funny, because I only found out about it two weeks ago! That is definately a more elegant way of doing it!
Jeff
Using Labview 7 Express
Message 11 of 12
(867 Views)
Here X Scale Increment should be replaced by X Scale Multiplier (under offset and multiplier). To my knowledge  X Scale Increment does not effect the data, but just the ticks on x-axis.From LabVIEW Help:
Cluster of offset(Xo) and multiplier(deltaX) for scaling values such that the final value equals (deltaX)*X + Xo.
Also the X Scale Minimum is redundant.
I have attached the modified vi.
Message 12 of 12
(725 Views)
