How to set name of X and Y in Graph?
what is the property name to set the name of the x and y at the border of a graph?
The good souding property XScale.Name.Label.text is not working (or is doing something different 🙂
best regards
TM
(2,238 Views)
For me the "X Scale.Name Label.Text" works as expected: it changes the scale label…
(2,221 Views)
Perhaps you should share some code and/or give a better explanation of what you were expecting. My suspicion is that the Xscale.Name Label.text is working properly but your code is not giving it the value that you think it is giving - but I'm only guessing since I have not seen the code.
(2,212 Views)
Attached a screenshot with marked text that i want to change.
(2,204 Views)
Accepted by OnlyOne
If you want to change the Y axis label then you should change Yscale, not Xscale.
(2,186 Views)
head->table
(2,183 Views)
Hi One,
@OnlyOne wrote:
head->table
Lesson learned: always provide code right from the beginning!
(2,140 Views)
