How to set pattern matching in vision assitant
Hi Sir,
When we do pattern matching,  how to set the config, to ignore the angle and size ?
Then no matter i rotate the object to a random angle, or zoom in/out,  we can still find the matching.
Thanks.
Learning from other people
(1,496 Views)
Accepted by topic author Brzhou
1. for pattern matching, need the same size, but we can set the angle;
2. if different size, we can use shape matching;
That is my understanding.
Thanks.
(1,450 Views)
Refresh this topic:
1. we set the template;
2. we choose an object pic, if I only want to compare one region of this pic to the template, how could i set the ROI ? exactly the same size to template ?
Thanks.
(1,299 Views)
