How to set properties of control references when I get them from "Controls []" property
If I create a reference to an indicator, I can set every property I need to.  I'm trying to duplicate what I did on a single boolean indicator on 20 of them.  I used This VI, to Pane, to Controls[]  The references aren't useful at all.  I tried casting them to more specific class (Boolean) but that doesn't work either.  How can I get an array of references that will work the same as ones I create by right clicking?
(2,788 Views)
You probably have not cast it to a class that was specific enough.  Which properties are you trying to set?
Attach a VI with the controls and what you have so far.
(2,773 Views)
Turn on scripting (if you havent already) and traverse the FP for all Booleans then test for them being not indicators
(2,758 Views)
