How to set smoothing filter average value from outside filter express VI?
I want to use smoothing filter from filter express VI for reducing noise in my continuous data acquisition,
Now my problems are :
- Is it possible to get the smoothing filter average value from outside filter express VI? ( So I can set the value from front panel )
- Why there are jumps at the beginning when I use smoothing filter for continuous data acquisition?
Alvin Chandra
(2,937 Views)
Hey,
the "jump" for continous data is there due to the fact that the data are not continous - this ramp comes from starting the VI. I think internally, along the width of your filter the dataset will be zero-padded, thus the ramp from zero to your value.
To change the filter settings while using an express VI, I am not sure if thats possible. https://www.ni.com/docs/en-US/bundle/labview/page/express-vis.html indicates that you cannot do that during runtime. Maybe just use non-express VIs.
Regards, QM
(2,921 Views)
Hi Chandras,
the ExpressVI is build by LowlevelVIs, so you can open the Frontpanel from Filter ExpressVI and take a look into the LowLevel Code.
I build the Filter without an ExpressVI, see attachment.
Christian
(2,893 Views)
