How to set the SE_SHUTDOWN_NAME privilege?
How do I set the SE_SHUTDOWN_NAME privilege so that I can execute ExitWindows on LabView 6.1 / Windows 2000?
KnowledgeBase document 2CTJ76G4 says that "a CIN is used to set the necessary privilege": what function / DLL?
(The attachment to KB #2CTJ76G4 is for LV 7.0; I am running 6.1.)
(6,266 Views)
You don't need a CIN, just the right calls to advapi32.dll and kernel32.dll:
LookupPrivilegeValueA
GetCurrentProcess
OpenProcessToken
AdjustTokenPrivileges
ExitWindowsEx
But it's easier to use the attached vi... Be carefull. Windows will shut
down (save first)!
Wiebe.
"allenf" wrote in message
news:5065000000080000009DD80000-1079395200000@exchange.ni.com...
[Attachment Shutdown.vi, see below]
(6,265 Views)
Thanks! That looks like it will do the trick!
(6,265 Views)
