How to set the default value of the controls to be zero and when I click on a control its value changes to 1.
Hello guys,
I have several image controls. I have a simple example of my problem.
On my vi I have 3 controls.
I want the default value of the controls to be zero and when I click on a control its value changes to 1.
How can I do this please? I have no idea how to do this.
Thanks in advance for your help.
Message 1 of 9
(1,993 Views)
Hi ngouda,
use a boolean control set to false by default. When the user clicks the control it changes to true...
When you need a numeric value you can use BooleanTo0/1 function.
Message 2 of 9
(1,970 Views)
Hi GrdW,
Thank you for your answer.
But I didn't quite understand, can you please show me an example?
Thank you
Sincerely
Message 3 of 9
(1,944 Views)
Accepted by topic author Ngouda
Something like this?
Message 4 of 9
(1,938 Views)
Hi Crossrulz,
Thank you very much for your answer.
Now I have another question please.
On my vi below I want to save the name of the control and its value (0 or 1) in a .txt file in this format: name of control= value of controls.
I got an error trying to do this. Can you please check?
Thanks in advance.
Message 5 of 9
(1,897 Views)
Hi Ngouda,
Which error do you got?
You know your 3 controls are booleans: why do you convert the control reference inside to loop to a string reference? Wouldn't it make sense to convert to a boolean reference???
Message 6 of 9
(1,880 Views)
Hi GerdW,
Thanks for your reply. Below is the error I have.
Yes you are right but I don't see how to collect the name of the control and concatenate it with its value. That's why I tried this not so good method.
Do you have a much simpler method and more sense please?
Thanks in advance
Best regards
Message 7 of 9
(1,866 Views)
I did some clean up of your code.  I would highly recommend avoiding using references and searches, etc.  Just use local variables to get your values.
Message 8 of 9
(1,847 Views)
Hi crossrulz,
Thank your very much for your help and for taking your time.
Your code is much simpler and less cumbersome, I like tool your suggestions.
Its work as I wanted it to, thanks again.
Best regards
Message 9 of 9
(1,818 Views)
