How to set the focus for a numeric control
Hi friends,
how can I set the focus for a numeric control in order to prompt read
a barcode?
All that I got is to set the "Tabbing Order" to ZERO but when I run
the program the numeric control doesn´t get the focus unless I press
the [TAB] key.
Thanks.
(8,298 Views)
> a barcode?
> the [TAB] key.
If you have a property node to the numeric, you can set the Key Focus to
True.
Greg McKaskle
(8,298 Views)
Even if it is a Necro-Post:
Thanks! Exactly what i was looking for! 🙂
Still the way to do it in LV2009
(7,478 Views)
Me too!
(7,246 Views)
